Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
Killhippie
Jun 10, 2023Prodigy
It does feel like they have just abandoned the RAXE500 and are pushing wifi 7 now, even though its not going to be useful for a while and still they don't fix the speed test over PPPoE its really frustrating. Its been 6 months since the last update.
perseid
Jul 23, 2023Aspirant
Disappointing that it's been over 6 months since the last firmware update for a router that I spent north of $500. The coders at Netgear are probably instructed to only work on developing new routers. Also, I'm sure that there are lots of new security holes arising after 6 months. Leaving routers insecure is a complete negligence and speaks loads of this company.
- michaelkenwardJul 24, 2023Guru - Experienced User
Someone turned up here recently asking for help with a router that is around 10 years old. I was surprised to find that new firmware for it landed a month or so ago.
Also, I'm sure that there are lots of new security holes arising after 6 months. Leaving routers insecure is a complete negligence and speaks loads of this company.Sadly, "I'm sure that" isn't a lot to go on. What makes you think there are "lots of new security holes arising"?
If you have encountered security issues, then Netgear has a reporting system that lets you alert it to new nasties.
NETGEAR Product Security | NETGEAR
