Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
perseid
Jul 23, 2023Aspirant
Disappointing that it's been over 6 months since the last firmware update for a router that I spent north of $500. The coders at Netgear are probably instructed to only work on developing new routers. Also, I'm sure that there are lots of new security holes arising after 6 months. Leaving routers insecure is a complete negligence and speaks loads of this company.
michaelkenward
Jul 24, 2023Guru - Experienced User
Someone turned up here recently asking for help with a router that is around 10 years old. I was surprised to find that new firmware for it landed a month or so ago.
Sadly, "I'm sure that" isn't a lot to go on. What makes you think there are "lots of new security holes arising"?
If you have encountered security issues, then Netgear has a reporting system that lets you alert it to new nasties.
NETGEAR Product Security | NETGEAR
