Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
rsun0525
Aug 30, 2023Guide
For the 6Ghz stuff I have it set to the following:
Channel: 37(PSC)
Mode: Up to 4800 Mbps
Security Options: WPA3-Personal
I'm using the multi-gig port (5) for the Internet, nothing is plugged into the "Yellow" port.
It reports as Down.
I have other 2.5GB devices plugged into my M4250-12M2XF, I tried multiple ports from the M4250-12M2XF that were all showing 2GB before with the previous devices, but did not plug any other 2.5GB device into the RAXE500, since I'm trying to use it for my main WiFi router, I don't have time to keep my entire home "down" during this process, I can say I'm almost at a point where I want to switch back to my eero 6e pro or Asus ZenWiFi Pro ET12 which both worked just fine at 2.5GB with that cable and port, etc. and just accept the RAXE500 is just too buggy and lack of recent firmware updates tells me maybe they've moved on from this device.
Aug 30, 2023Guru - Experienced User
Channel: 37(PSC)
What brand and model 6Ghz devices do you have connecting to the 6Ghz radio on the RAXE?
I'm using the multi-gig port (5) for the Internet, nothing is plugged into the "Yellow" port. Trying to see if the internet port shows same thing if you use this port as a quick test. Then move back to the MG port.
It reports as Down.
Just checking to see if a different 2.5Gb supporting device shows same speed at the MG port, other than the switch your using. I have a Realtek PCI 2.5Gb ethernet card connected to my RAXE, however it's in Bridge mode. I'll check mine in AP mode and see what I find out.
- rsun0525Aug 30, 2023Guide
For my 6Ghz devices, I've got Samsung Galaxy Fold Z5, Samsung Galaxy Flip Z 5, Lenovo ThinkPad P1 Gen 4, Google Pixel 7 Pro, Dell Optiplex 7000 Intel Gen 12 chipset
When I try to switch it to the yellow port, it still detects at 1gb and back to the 5th port and stays 1gb
For the 'bridge mode" you talk about, that's under Wireless settings "use other operation mode" right? Can you share with me a document why you would do this vs. setting it to Access Point mode? They can't possibly do the same thing? The key for me is that I want my firewall to give the IP addresses, so I'm confused if you didn't set it to AP Mode, what would happens if you set it to "bridge mode", as I thought AP mode would turn it off as a router, but not sure bridge mode do under Wireless settings?
- FURRYe38Aug 30, 2023Guru - Experienced User
Thank you for this.
What did the status say in the NH app when it was connected to the yellow internet port?
Bridge mode is wireless bridge mode. Works as a client wireless devices connected to a wifi signal.
