Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
strykerzr350
Sep 06, 2023Guide
Why no new firmware? It has almost been a year since we have gotten a firmware update on this product.
- FURRYe38Sep 06, 2023Guru - Experienced User
Only been 9 months.
Something not working for your with your RAXE500?
- strykerzr350Sep 13, 2023GuideEverything is working fine with it, just the wireless lights and internet lights does not blink as advertised.
- FURRYe38Sep 13, 2023Guru - Experienced User
Mine don't blink either. NH may have made a change.
- michaelkenwardSep 07, 2023Guru - Experienced User
Maybe there is no need. If the current version has no problems and there are no serious security issues that need mending, why put people through the hassle? Updates are not without their own risks.
- p0se1d0nXSep 07, 2023StarExactly! Really don’t want Netgear heading down the same downward spiral path as Asus where they do weekly updates that fixes something and breaks several others in the process. No thank you!
I left Asus years ago and never looked back for this reason. Who the heck needs weekly fw updates? Talk about over kill.- michaelkenwardSep 08, 2023Guru - Experienced User
p0se1d0nX wrote:
Exactly! Really don’t want Netgear heading down the same downward spiral path as Asus where they do weekly updates that fixes something and breaks several others in the process. No thank you!That's odd. From some of the messages we see here you would think that Asus walks on water in router design.
