Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
rsun0525
Sep 12, 2023Guide
So after moving the back and forth between the Internet port and port 5, it's now showing up as 2.5G, so now the last problem I have is once in a while the 6G band "dies" and doesn't accept any new connection, so only way to solve is to reboot.
Sep 12, 2023Guru - Experienced User
Been running my RAXE500 for past several days.
6Ghz still working.
Manual channel 37 for 6Ghz.
AX210 Intel PCI adapter in a desktop PC:
- rsun0525Sep 12, 2023Guide
Remember, I said existing connections would still be connected, it's new ones that can't connect and if my existing connection is disconnected, I can't connect back.
- FURRYe38Sep 12, 2023Guru - Experienced User
I had just re-connected my AX210 on this one PC to take that screen capture as the one PC had been ethernet connected instead of wireless.
