Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
rsun0525
Sep 12, 2023Guide
Remember, I said existing connections would still be connected, it's new ones that can't connect and if my existing connection is disconnected, I can't connect back.
Sep 12, 2023Guru - Experienced User
I had just re-connected my AX210 on this one PC to take that screen capture as the one PC had been ethernet connected instead of wireless.
