Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
Razor512
Dec 12, 2023Prodigy
Yay, new firmware update. RAXE500 Firmware Version 1.2.13.100
Bug Fixes:
Fixes the issue where Anywhere Access doesn’t work when Web Services Management is turned on.
Fixes the issue where the on-board log doesn’t automatically clear after logs are emailed.
Fixes the issue where the download and upload values shown by the built-in speed test are lower than the actual line rate.
Fixes the issue where the 2.4G band doesn’t switch to 40 MHz when 2.4G 20/40 MHz Coexistence is disabled.
Fixes the issue where iPhones cannot connect to the 2.4G guest SSID successfully when WPA3 encryption is enabled.
Fixes the issue where the Nighthawk App shows errors when onboarding with PPPoE.
Fixes the issue where Nighthawk App users see the “Something went wrong” error message when trying to enable Anywhere Access.
Fixes the issue with low performance when Port Aggregation LACP mode is enabled.
Fixes the issue where port forwarding doesn’t work when the port range is set to 20-22.
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/RAXE500-New-Firmware-Version-1-2-13-100-Released-firmware/td-p/2350824
