GChuck
Dec 26, 2023Aspirant
RAXE500 no longer get attack warnings
I've never been so unhappy after purchasing a router as I have been with this RAXE500. But I'll have to live with it now that I've spent the $600 to get it! Yesterday I upgraded the firmware fro...
- Jan 09, 2024
michaelkenward Netgear have changed the attack logging so I apologise as I was surprised its so different, but it is the way its meant to be now on The RAXE500 as you guessed.
I was given this reply via Netgear. "Engineering comments: Understood and we changed the DoS attack determination rules since there are a lot of false alarms in previous version. It’s the enhancement in v1.2.13.100.
I don’t think it is an issue."Also there is a trial version to cure option 60-61 missing but users with that issue would need to contact Netgear.
GChuck
Dec 28, 2023Aspirant
Thank you for the response regarding the DOS attack messages.
Now I have one further question. Are these DOS type messages generated by the firmware in the router, or by the Armor software. I reset to factory my router and then reconfigured it but I did not use the Nighthawk app (so hopefully did not enable the Armor software). I did this to allow me to use the “Access Control” settings in the router, which were unavailable as long as the Armor software was enabled. By the way, I did purchase a year’s worth of Armor, but don’t want to enable it until I can figure out if it is useful or not.
GChuck
michaelkenward
Dec 29, 2023Guru - Experienced User
We see regular reports here of logs loaded with DOS Attacks even when the router has never seen a whiff of Armor.
That's for you to decide. I know nothing about Armor. I don't pay for things that I can't see the need for.
