GChuck
Dec 26, 2023Aspirant
RAXE500 no longer get attack warnings
I've never been so unhappy after purchasing a router as I have been with this RAXE500. But I'll have to live with it now that I've spent the $600 to get it! Yesterday I upgraded the firmware fro...
- Jan 09, 2024
michaelkenward Netgear have changed the attack logging so I apologise as I was surprised its so different, but it is the way its meant to be now on The RAXE500 as you guessed.
I was given this reply via Netgear. "Engineering comments: Understood and we changed the DoS attack determination rules since there are a lot of false alarms in previous version. It’s the enhancement in v1.2.13.100.
I don’t think it is an issue."Also there is a trial version to cure option 60-61 missing but users with that issue would need to contact Netgear.
GChuck
Dec 30, 2023Aspirant
Thanks for that answer. It's what I thought. I think I might revert my router back to my previous version (1.0.10.86) and then upgrade it to V1.0.12.96 to see what else breaks. This is my first (and probably last) Netgear router. Can't say I'm impressed!
GChuck
Killhippie
Dec 31, 2023Prodigy
All routers have bugs, don't let this put you off, the RAXE500 is a capable router, speedtest over PPPoE was broken in V1.0.12.96 and you cant use 40Mhz on 2.4Ghz (which you should not be anyway) I had no issues with that firmware for a year. I'm staying on this latest one, I've seen this bug on the RAX120 years back and with some of the other issues Netgear will get this fixed, but if you want run V1.0.12.96 just keep an eye out for possible security updates that means running 1.2.13.100. Also the router is blocking port scans and etc its just not logging them and many people turn the logging of that event off as its annoying but you still have the protection, after all its only a log. The router is still working as it should to protect you and this version although with a few bugs has a lot of fixes too. Id rather stay up to date for security than roll back and be vulnerable. the version you were running was quite old, its best to stay up to date for your own protection if possible. Netgear are aware of the issues. If they pulled the posts to option 60-61 not working (not saying they did) I would say these told people to roll back who use that option and will get it fixed.
- GChuckJan 01, 2024Aspirant
Thanks for that reply. I have decided to stay with version 1.2.13.100 for a while just to see how long it take Netgear to fix the two issues I'm seeing (not logging attacks and 6G devices not showing).
I also seem a little more comfortable with the router now that I have removed the Armor portion. I can again see (and control) who gets access to my network without having to try and get it to work with the underpowered and basically useless Armor app.
I do like the speed though. Getting gigabit throughput on both my desktops. One running an Intel AX-201 and the other an Intel AX-210. I did think I would get better throughput on the 210, but both machines getting about the same!
Will keep experimenting with the device settings to see what else it is capable of doing.
Thanks again.
GChuck
- michaelkenwardJan 01, 2024Guru - Experienced User
Which issue is that?
The one about "not logging attacks" is not an "issue". The problem was that it logged attacks that weren't real. So, that is a fixed issue for many people. Are you saying that you want to see those false reports?
As to 6 GHz devices, what is the issue there? Are they connected and not visible? Or can you see them and they don't say "6 GHz"?
The first issue is that the logs are empty. With the exception of seeing my admin login entries, time synchronization and updates to Access Control, I saw no "attack" entries and found that unusual. But as I am new to this router, I never really experienced the full gamut of false positives that I keep hearing about. So this is probably a non-issue.
The second issue I'm seeing is that when I look at the "Attached Devices", I see the "Connection Type" displayed as "Wired" or "5G Wireless" or "2.4G Wireless", but for my 6G devices, they show up as only "--". In the previous firmware that I was using (V1.0.10.86), these devices did show up as "6G Wireless". Not a big deal, but if the small stuff is missed, then I sure hope that important stuff is not!
It would be nice too if the documentation matched the device.
GChuck
