SniperStorm
May 03, 2022Tutor
RAXE500 Overriding my Static IP Addresses.
I have a RAXE500 Router. I have several devices on my network that have a static ip address. IE 192.168.1.18 and are wired. Lets say for example I reboot my router for whatever reason. My router wil...
CD_router_888
May 03, 2022Guide
Or you can use DHCP reservation function.
- plemansMay 04, 2022Guru - Experienced User
I'll echo what CD_router_888 said and say use the reservation function.
I've been using it on my RAXE and its worked fine for address reservations.
