Tigerwife
Sep 26, 2023Guide
RAXE500 power adapter replacement................
HI Guys I found that it is NOT possible to buy a replacement adapter for RAXE500 / RAX200 It come with 19V 3.16A 7.4mm PD........ but the biggest problem is the 7.4mm without a middle pin in...
- Oct 03, 2023
I buy it from Hong Kong / Macau distributor (Winco)
I bought it from their office directly as they do not sell it online.
HK$350 about USD45
The most funny is that netgear USA headoffice not sell it ...........
Some people in this forum said netgear not selling power adapter is NOT truth.
take a look at the link below
https://www.netgear.com/home/accessories/pa7000p/
https://netgear.techgear.com.hk/products/pa-332-10939-02?_pos=2&_sid=e14e96854&_ss=r
Netgear selling 12V power adapter online, but they just NOT selling 19V power adapter online only.
Even a india online shop selling this original RAXE500 / RAX200 power adapter.............
https://www.hatke.co.in/products/19v-3-16a-dc-original-genuine-netgear-ac-dc-power-adapter
Good Luck!
Best Regards,
Tiger 🙂
schumaku
Oct 03, 2023Guru - Experienced User
The small inner pin is a relict from a second "always on" 5Vcc voltage available on some power supplies, and used to power some "always on" +5V devices like internal Modems or network adapters on some notebooks. Some users suggested (and did) cut-off this additional +5V Vcc pin.
It's an unlucky oversight the hardware designers have not used the variant with the additional center so any probably locally available power supplies with the additional 5Vcc pin (un-soldered) could be used.
Checking with my CAX80, RAXE500 and RAX120v2 and a RAX50v2, the CAX80 and RAXE500 both have the larger plug 7.4mm / 5mm without center pin inside. The RAX50v2 and RAX120v2 both have the smaller plug with the center contact pin in the middle. I can only presume that at least the RAX120 and lower model series are all the smaller plug. I don't have the RAX200 so not sure about that model. I presume anything RAXE will have the larger plug that doesn't have the center pin for these model routers.
It's not an oversight when it comes to the center pin missing, more like power design and flow needed by these devices that may require more current and also regulatory considerations would be a factor as well.
- schumakuOct 04, 2023Guru - Experienced UserWhen referring of the center pin, we're talking of the 19V devices with the 7.4mm / 5mm outer and inner contact. Some variants plugs have a thinner additional contactor, originally used for a 5Vcc always-ob power source. Nobody does talk here of the smaller and more common industry standard power plug connectors with just two contacts, as in use on lower cost hardware, for 12V DC e.g with smaller and newer ones supporting 2.5 and 3.5 Amps power supplies.
- FURRYe38Oct 04, 2023Guru - Experienced User
Yep. Nobody talks about the un-common plugs like these larger ones which is why one reason this thread was started. These are not common plugs and only seen on these particular devices and newer 9 series Orbi systems.
Seems like these larger routers that have more features and do more seem to required more power specs so maybe one reason why NG went with this particular plug design.
