ABONE
Jul 09, 2021Aspirant
RAXE500 QOS Settings Missing
Back On 2021-04-06 16:27:45 on Case Number 44416487 I chated with a Netgear Support Engineer and helped me find the QOS setting for the RAXE500 / AXE11000 WiFi Router. They were not in the usual pla...
tonydi
Jul 12, 2021Luminary
Oh, you're definitely not crazy ABONE. :smileyvery-happy:
It was there as evidenced by this screencap from earlier this year....
I can only guess that QoS was some sort of problem and since many people disable it they felt it was better to just remove it. Maybe it'll come back at some future point.
tonydi
Well, no idea why my screen cap doesn't appear, it was there before I clicked Post.
- ABONEJul 16, 2021Aspirant
I see your screen shot and thank you for confirming it was indeed there. That is exactly where I was accessing it, and succefully using it. Now I would like someone maybe from Netgear support to chime in and let us know where it went? Why it was taken awway? and if its coming back?
Thanks again
- tonydiJul 16, 2021Luminary
Yeah, weird about the picture not showing up initially.
I'm afraid that the info you seek may be outside the purview of the Netgear people who monitor this forum, or perhaps they might know but be restricted in what they can say. Let's see if they comment.
- Christian_RJul 21, 2021NETGEAR Employee Retired
Hello Community,
The RAXE500 currently does not support QoS.
Christian
- tonydiJul 21, 2021Luminary
Well that was helpful.
