ABONE
Jul 09, 2021Aspirant
RAXE500 QOS Settings Missing
Back On 2021-04-06 16:27:45 on Case Number 44416487 I chated with a Netgear Support Engineer and helped me find the QOS setting for the RAXE500 / AXE11000 WiFi Router. They were not in the usual pla...
tonydi
Jul 12, 2021Luminary
Well, no idea why my screen cap doesn't appear, it was there before I clicked Post.
ABONE
Jul 16, 2021Aspirant
I see your screen shot and thank you for confirming it was indeed there. That is exactly where I was accessing it, and succefully using it. Now I would like someone maybe from Netgear support to chime in and let us know where it went? Why it was taken awway? and if its coming back?
Thanks again
- tonydiJul 16, 2021Luminary
Yeah, weird about the picture not showing up initially.
I'm afraid that the info you seek may be outside the purview of the Netgear people who monitor this forum, or perhaps they might know but be restricted in what they can say. Let's see if they comment.
- Christian_RJul 21, 2021NETGEAR Employee Retired
Hello Community,
The RAXE500 currently does not support QoS.
Christian
- tonydiJul 21, 2021Luminary
Well that was helpful.
- ABONEAug 17, 2021Aspirant
Christian
Thanks for you post, however the point is that out of the very expensive Box the softwar / firmware of the RAXE500 did support QoS.Which is shown in tonydi's attached screen shot. I can also confirm it worked and when selecting the QoS button / option the menu screen also had the onboard speed test option which helpful and common thing for Netgear Routers with QoS.
I'm not sure if you work for Netgear, or have access to someone that does, but the questions for Netgear are.
Why was QoS taken away from the RAXE500?
Will QoS be returned to the RAXE500?
If so when?
Thanks
ABONE
- AltsaiNov 16, 2021NETGEAR Expert
QoS is supported by the candidate FW so you may check with support team for the beta version for trial first.
