ABONE
Jul 09, 2021Aspirant
RAXE500 QOS Settings Missing
Back On 2021-04-06 16:27:45 on Case Number 44416487 I chated with a Netgear Support Engineer and helped me find the QOS setting for the RAXE500 / AXE11000 WiFi Router. They were not in the usual pla...
Jan 28, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router her at the modem? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers?_ga=2.190834155.1964120923.1641394007-133989108.1641394007
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
Try Option #2 first...
IllWillTaboo wrote:
Is there an update on the QoS supported trail firmware? I am trying to use it with an xfinity modem to no avail. If I turn QoS on and reboot the router, it appears to be connected but totally fails. If I turn QoS off and reboot, it works.
IllWillTaboo
Jan 28, 2022Aspirant
Thanks for the extensive response. V1.0.9.72_2.0.36 is loaded, and I've had the gateway (Model:DPC3941B Vendor:Cisco) in bridge mode since my first attmept. I just can't get it to work in QoS. Even setting certain machines to Highest priority doesn't work. I'll set a workstation to Highest and click Apply and it just sets back to High. Moot point though as it isn't working anyway. I really apreciate the help. Tomorrow I'll try setting it up as an AP and if that doesn't work, I guess I'll head back to microcenter.
