Armorless
Nov 29, 2024Aspirant
RAXE500 Questiions and performance?
Hi everyone, hope you all had a nice holiday. I am not sure if to be concerened or if I am overthinking, but after ordering a static IP from my ISP, the second light on my RAXE500(network light) is n...
michaelkenward
Nov 29, 2024Guru - Experienced User
Armorless wrote:
Hi everyone, hope you all had a nice holiday. I am not sure if to be concerened or if I am overthinking, but after ordering a static IP from my ISP, the second light on my (network light) is now orange/amber.
Did you tell the RAXE500 that you now have a static WAN IP address? (Do not confuse that with a fixed local IP address.)
Probably here:
- Internet Setup
- Internet IP address
Or Set up an IPv6 fixed Internet connection
- Advanced
- Advanced setup
- IPv6
Just another user with time on their hands.
- ArmorlessNov 29, 2024AspirantHi,
Thank you for a quick response.
Yes, I switched from “Get Dynamically from ISP” to “Use static IP address” and used the information provided by my ISP. I also have manually adjusted the DNS to the ISP’s recommended DNS servers
Unfortunately my current ISP doesn’t support IPV6 for either dynamic or static. I can only setup a “6to4” tunnel which i’ve read degrades connectivity.
Thank you!- FURRYe38Nov 29, 2024Guru - Experienced User
Please post a copy and paste of the CM modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- ArmorlessNov 29, 2024Aspirant
Apply Cancel Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
(on zero)Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 213000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 41 213000000 Hz -1 dBmV 44.7 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 14500000 Hz 45.8 dBmV 2 Locked ATDMA 2 2560 Ksym/sec 33400000 Hz 44.3 dBmV 3 Locked ATDMA 3 2560 Ksym/sec 36750000 Hz 44.3 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
CodewordsUpstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power(not enabled)
Current System Time:Fri Nov 29 16:53:35 2024System Up Time:07:37:17
