Armorless
Nov 29, 2024Aspirant
RAXE500 Questiions and performance?
Hi everyone, hope you all had a nice holiday. I am not sure if to be concerened or if I am overthinking, but after ordering a static IP from my ISP, the second light on my RAXE500(network light) is n...
Armorless
| Fri Nov 29 17:02:55 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 17:02:55 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 16:32:52 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 16:32:52 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 16:32:37 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 16:32:37 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 6 13; New Profile: 9 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 13:12:08 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 13:12:08 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 5 13; New Profile: 6 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 12:49:34 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 12:49:34 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 6 13; New Profile: 5 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 12:19:31 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 12:19:31 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 5 13; New Profile: 6 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 10:31:30 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 10:31:30 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 6 13; New Profile: 5 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 10:01:27 2024 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 10:01:27 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 5 13; New Profile: 6 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:23:44 2024 | Notice (6) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 49 50; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:23:44 2024 | Notice (6) | CM-STATUS message sent. Event Type Code: 22; Chan ID: 49 50; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:26 2024 | Warning (5) | Dynamic Range Window violation |
| Fri Nov 29 09:17:26 2024 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:26 2024 | Warning (5) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:26 2024 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 13; New Profile: 5 13.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:23 2024 | Notice (6) | DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:22 2024 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:17 2024 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Fri Nov 29 09:17:16 2024 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| Time Not Established | Warning (5) | Lost MDD Timeout;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Wed Nov 27 23:22:09 2024 | Notice (6) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 49 50; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 3.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Wed Nov 27 23:22:09 2024 | Notice (6) | CM-STATUS message sent. Event Type Code: 22; Chan ID: 49 50; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
| Wed Nov 27 23:12:21 2024 | Warning (5) | Dynamic Range Window violation |
| Wed Nov 27 23:12:21 2024 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=94:a6:7e:d8:74:2c;CMTS-MAC=c0:94:35:3a:83:b2;CM-QOS=1.1;CM-VER=3.1; |
Nov 29, 2024Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
How does the other down channels look?
