Topology's avatar
Topology
Virtuoso
Mar 06, 2025
RAXE500 Radio Specifications
Does anyone know the technical specifications of the 2.4GHz, 5GHz, and 6GHz radios in the RAXE500 router (e.g., transmit power, antenna gain)?  Interestingly, this information does not appear in the product data sheet or user manual.
Thank you.
1 Reply
    Thank you.
    Do a web search for raxe500 fcc id.  I use Duck Duck Go.
    Come up with the FCC certification details here:  https://fccid.io/PY320300508
    You should check the specific FCC ID number on your device.
    All the details you could ever ask for, and then some!
