GolfDude
Dec 02, 2021Aspirant
Raxe500 Readyshare stopped working
ive had an extenral drive setup with readyshare for a while now, but now the rotuer isnt seeing the drive anymore, it says NO DRIVE, and i cant connect to it.. if i plug it in via usb to my pc, every...
Dec 02, 2021Guru - Experienced User
Do other external drivers work with the router?
Has the Router and USB drive been fully powered OFF for 1 minute then back ON?
GolfDude
i tried attaching another drive i actually just got this week, and it also shows as no drive found on the router for readyshare.. both dont show up,
- FURRYe38Dec 02, 2021Guru - Experienced User
Try a factory reset on the Router with the USB drive disconnected from the router. Complete the setup then power OFF the router. Connect the drive and turn ON the router. See if the drive appears.
- GolfDudeDec 02, 2021Aspirant
the unplug did the trick.. except now it doesnt want to find the shared folder, despite it showing the shared folder
aka:
Click on readyshare in my network list
shows my shared folder
i click on said folder, and it says the path wasnt found
if i try to make a new shared folder, it blanks the box out and doesnt allow it.. if i try to select an existing folder, it wont register it being picked
