Jbarrick17
Apr 08, 2022Aspirant
RAXE500 router throttling upload speed via wifi
Hello, I recently purchased a Netgear Nighthawk RAXE500 tri-band router. I have a Verizon Fios gigabit connection. There is a CAT7 cable running from my ONT box to the router. There is also at CAT7...
Apr 08, 2022Guru - Experienced User
Is the CAT7 cable between the Modem and router UTP or STP?
What port are you using on the RAXE to connect to the ONT? Yellow WAN Port or the 2.5Gb port?
What wifi devices are you connecting and speed testing with?
Is Smart Connect enabled?
What channels are you using?
Is Beamforming and MIMO enabled?
Jbarrick17
Beam forming is on
I'm using Channel 02 on the 2.4ghz band, channel 40 on the 5ghz, and channel 53 (psc) on 6ghz.
Verizon ONT i-211m-l
mfr ALCLF4584DE9
