Jbarrick17
Apr 08, 2022Aspirant
RAXE500 router throttling upload speed via wifi
Hello, I recently purchased a Netgear Nighthawk RAXE500 tri-band router. I have a Verizon Fios gigabit connection. There is a CAT7 cable running from my ONT box to the router. There is also at CAT7...
CD_router_888
Apr 10, 2022Guide
Hi Jbarrick17,
Which Speedtest server were you choose? Sometimes use different speedtest server would gain different results.
You can try the nearest one.
