Federico-Venier
Nov 16, 2022Aspirant
RAXE500: should I buy or does it keep disconnecting from Internet?
if it is known to be buggy, I prefer not to buy to then return to Amazon. PLEASE HINTS My current D7000 (=R7000+Modem) FW V1.0.1.84_1.0.1 connected to an external modem at 1Gb/s, keeps disconnec...
Nov 16, 2022Guru - Experienced User
Try bridging the D7000 modem to put it in modem only mode.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Federico-Venier
I need to use it as a router, and "router only" is not available
LAN should be good. Anyway even disconnecting and reconnecting does not fix it.
What's your feeling for the RAXE500? I have a 1Gb/s fiber connection and about 15-20 devices
- FURRYe38Nov 16, 2022Guru - Experienced User
So you need to use the modem in router mode? The D7000 does have a bridge mode. If so, then you might turn OFF the D7000 wifi radios and use the modems DMZ for the RAXE router then.
- Federico-VenierNov 16, 2022Aspirant
I just want to dismiss the D7000, and buy a new RAXE500 that I will connect to a Nokia fiber modem where I have 1 1Gb/s plan. My only concern is about the RAXE500: I want solid product, not something I need to reboot every while.
No problem to update FW time by time, it is an issue if my video conference drops.
- microchip8Nov 17, 2022MasterDo you need such an expensive beast of a router? Why not go for the lower RAX models. I run a RAX43 here with ~20 connected devices and don't experience any problems. Speed is steady, it doesn't drop connections, is rock solid
