eal6553
Apr 18, 2021Follower
RAXE500 SSH?
Re Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi Router / RAXE500
1. What OS does this router use (linux)?
2. How do I SSH into it? WHen I try I get access denied.
2. How do I change the login time out? It seems to last just minutes. I am constantly having to log back in.
3. Logs? Support for a syslog server, SNMP etc.
Thanks!
Ed
1 Reply
> [...] RAXE500
Firmware version? Connected to what?
Too modern/fancy for me, so I know nothing, but...
Some variant of GNU/Linux would be a pretty safe bet.
> 2. How do I SSH into it? [...]
I don't know. I wouldn't bet that it's a supported feature. A
problem with using SSH (or, on older models (and firmware versions),
Telnet) to make configuration changes is that it can be hard to make
such changes persist through a restart. Handy for exploration, though.> [...] WHen I try I get access denied.
When you "try" _what_, exactly? As usual, showing actual actions
(commands) with their actual results (error messages, LED indicators,
...) can be more helpful than vague descriptions or interpretations.Especially when using a command-line program, copy+paste is your friend.
A complaint like "access denied" (as opposed to, say, "connection
refused") suggests that there's some kind of sshd listening. I'd expect
a user name like "admin" to have a better chance than some others. Of
course, with my weak psychic powers, I can't see what you did.> 2[']. How do I change the login time out? It seems to last just
> minutes. I am constantly having to log back in.Having the web browser save the credentials can help. I've never seen
a documented/supported way to adjust that parameter (which gets
occasional complaints here).> 3. Logs? Support for a syslog server, SNMP etc.
The User Manual mentions e-mail. My old D7000 claims to support
syslog, but I've never tried it. (ADVANCED > Administration > Logs :
Syslog) I've never seen SNMP support on a Netgear consumer-grade
router.
