jdbyyc
Mar 27, 2025Aspirant
RAXE500 stops transmitting 2.4GHz and 5GHz
Has anyone else experienced where the 2.4GHz and 5GHz channels just stop transmitting? But the 6GHz band/channel is fine. The indicator lights on the device itself say that all three are transmitting...
Mar 28, 2025Guru - Experienced User
How long have you had the unit for?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed? Does this bring back the frequencies?
Does the router feel extra warm or hot?
