jdbyyc
Mar 27, 2025Aspirant
RAXE500 stops transmitting 2.4GHz and 5GHz
Has anyone else experienced where the 2.4GHz and 5GHz channels just stop transmitting? But the 6GHz band/channel is fine. The indicator lights on the device itself say that all three are transmitting...
Mar 31, 2025Guru - Experienced User
Any progress on this?
jdbyyc wrote:
Has anyone else experienced where the 2.4GHz and 5GHz channels just stop transmitting? But the 6GHz band/channel is fine. The indicator lights on the device itself say that all three are transmitting but when I check with a Wifi Analysis tool only the one (6 GHz) is transmitting (and obviously my family is complaining that the Internet dropped as most devices are on 2.4/5).
I have also experienced a decrease in range lately that I can't explain due to Wifi channel interference or anything else. I've only had this thing for a few months and during that time it has been rock solid (despite there being a silly/annoying UI bug).
Is there some way I can run diagnostics on the antennas?
