oliversimpson's avatar
Dec 06, 2023
RAXE500 The IP address conflicts with the WAN IP subnet
I am in the process of configuring my RAXE500 to join my LAN. It currently acts as its own separate LAN - with internet being provided by another router.   I have internet in my house balanced by t...
  • oliversimpson's avatar
    oliversimpson
    Mar 20, 2024
    Hi Everyone.
    Sorry it took so long to get a response out.
    Shortly after the last message, I spoke to Netgear support — who agreed with me that it was inconsistent that the feature was disabled, but the manual did not specify that it should have been disabled.
    So, we climbed up their levels of technicians, and eventually, I was notified that they had changed the setting for the next update, and last I checked it worked fine.
    What's the most annoying is that I had to buy a 2.5G netgear switch in the meantime because of the wait.
    Now I just use it as a 6GHz router in my computer room. It works great with my iPhone 14 Pro Max and HP ZBook Firefly G10 which both support the band.
    Thanks for all your help previously. I have only responded to this now as I have opened another support discussion on my Orbi Pro Mesh system.
