cabwav
Apr 12, 2024Tutor
RAXE500 timeouts
I recently installed a RAXE500 router. When selecting a menu item or switching to another menu item I have to re-enter the userID and password. The router also frequently reports ' timeouts', e.g. wh...
- Apr 12, 2024
What browser are you using?
Happens with other browsers? Try MS Edge or Firefox.
cabwav
Apr 12, 2024Tutor
Thank you for your reply. Although I don't remember doing a firmware update (but in hindsight an update may have been done automatically), the factory reset solved the problem. Thank you for pointing me in the right direction!
Apr 12, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
