ivn_24_syd
Dec 23, 2024Aspirant
RAXE500 Unable to set up iinet (IP provider) PPPoE configuration new device
Hi All, I recently contacted Netgear support because I couldn’t get PPPoE configuration to work on my router. I’m with iiNet, which requires user verification to connect to the internet with non-IP r...
- Dec 24, 2024
MLB999 wrote:
I have the same problem. Not sure about the support response re firmware updates as its not possible to update the firmware if the router is not connected to the internet.
It probably wouldn't solve your problems, but as long as you can get a wired local connection into the router you don't have to be on line to update firmware. You can download the firmware with whatever you are using to access this place. Use a USB drive to transfer it to a PC if needed. Unzip and then go through the manual update with the router.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Just another user with time on their hands.
ivn_24_syd
Hi I initially chose the max 32 character password as per guidelines then we chose a simple Welcome@123 and it still didn’t work. Something is not right and the operator sort of went off a few times to check something but nothing helpful came out of it. Really disappointing. Not sure what to do next or should I call them again at some point? Puzzled by the whole thing.
In response to plemans.
The password was actually suggested by the NETGEAR operator and I thought she would know what the acceptable format would be for passwords. But still din't work.
Dec 23, 2024Guru - Experienced User
Would be best to check with the ISP iinet and see what actual PPPoE confguration is needed to be used on the RAXE.
What FW Version is loaded on the RAXE router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Which port is being used to connect the RAXE to the ISP modem/ONT? Yellow WAN port or the Multi-Gig port?
- MLB999Dec 23, 2024Guide
According to iinet, the settings should be WAN type PPPoE, username and password (same as used to access iinet toolbox) VLAD ID turned ON and set to 2.
I can't see how I can set the VLAD ID as the nighthawk app only asks for username and password under advanced settings.
- michaelkenwardDec 24, 2024Guru - Experienced User
- ivn_24_sydDec 24, 2024AspirantThank you for your thoughtful response. That’s precisely what I did; however, connecting it via a local cable with a Mac proved tricky as I needed additional equipment. I worked through all the troubleshooting instructions I could find online and ultimately resolved the issue by resetting the NBN modem and router multiple times. Eventually, I was able to access the router’s advanced setup interface, and everything functioned smoothly from that point.
What I found unacceptable was the attitude of the Netgear support staff during my second call. The representative was extremely rude and dismissive, forcing me to terminate the call. I was shocked by his tone and the audacity to speak to a customer in that manner.
I am currently trying to locate a feedback form to report this experience but haven’t found one yet. Overall, my impression of Netgear’s support has been disappointing so far.
Thank you all for your support!
