cybot
Nov 17, 2022Luminary
RAXE500 using readyshare cause router to malfunction and causes PC net adapter to give weird errors
firmware version: Firmware Version V1.0.10.86_2.0.40 I have a new RAXE500 that i have hooked a USB 3.0 4Tb drive upto for use in backing up my PC. I am able to access the drive over the network t...
Nov 17, 2022Guru - Experienced User
What is the brand and model of this USB drive your using?
Has the Intel adapter drivers been updated? What version is currently loaded for it?
Does this happen if you disable the wifi adapter and connect the PC via ethernet?
cybot
Nov 18, 2022Luminary
i have located the ethernet cable and will be switching over for testing later today. If my mom suddenly tells me to say she can no longer get onto the network, I will know the router is misbehaving again. of course if i suddenly no longer have network access via ethernet, the same will be true as well. here is hoping for results either way.
