walter701
Oct 27, 2021Tutor
RAXE500 web page wont load security
I have a RAXE500 when I click on security-access control, the web site does not load then stops responding and kicks me out. I have to restart the router because it becomes extremely slow after this,...
- Oct 29, 2021
Yes, v1.0.7.68 broke the Access Control List but it has been fixed in the next firmware. Sorry, I'm not privvy to when that will be released, but hopefully it's not too much longer.
Oct 27, 2021Guru - Experienced User
Let me know how it goes after the reset.
If that doesn't help, wait a bit. I'm on a little newer firmware version that I'm testing and maybe it fixed an issue with access control.
tonydi
Oct 29, 2021Luminary
- walter701Nov 04, 2021Tutor
Just updated for Firmware Version V1.0.8.70_2.0.36 and the issue is fixed now :)
- FURRYe38Nov 04, 2021Guru - Experienced User
Enjoy.
- tonydiNov 04, 2021Luminary
Just curious as to how you got that FW version. Did your RAXE500 automatically download it? Mine is on a 1.0.7 version and the internal update check says there's no new version.
- plemansNov 04, 2021Guru - Experienced User
A lot of time the auto-update server gets it first and even then, sometimes its only to a select few to ensure it functions properly. then it gets pushed to a larger release. I'm not showing it on the support site and mine was on a different firmware so I can't check the auto-update on mine.
