Deepthi_
Mar 29, 2023Follower
RAXE500 WIFI 6E Router telnet console help
Hi, I was trying to configure an SSID with WPA3 security mode via router command line interface, but I am getting 'wl unsupported' error while issuing the following commands: wl -i wl2 sae_pwe_h...
Kitsap
Apr 06, 2023Master
Deepthi_ wrote:Hi,
wl -i wl2 sae_pwe_hnp_enable 0
wl -i wl2 sae_password "1234567890"I am able to do the same through router web UI,but not from CLI.
Where can I find more info on supported wl commands for this device (RAXE500)?
You might get some responses to your question over on the Small Net Builders forum. Try here:
https://www.snbforums.com/forums/netgear-ax-wireless-wi-fi-6-6e.58/
