sudo-visudo
May 26, 2022Aspirant
RAXE500 WiFi 6E SSID
Does Smart Connect include the 6E (6 Ghz) network if you use the same SSID for all networks? In other words, if you have Smart Connect enabled and are using a 6E compatible device, will it switch you...
May 27, 2022Guru - Experienced User
No. smart connect doesn't currently incorporate the 6ghz signal.
I've got named separate so I can select it since the signal is much shorter range than the 5ghz. That way I can choose when to connect to the 6g signal.
