rlmcneary2
May 16, 2023Aspirant
RAXE500 wifi speeds dropped
I've had a RAXE500 for about a year and in the past two weeks the wifi speeds have dropped off. I did not make any changes to the router in the months prior to the speeds dropping off. firmware: ...
- May 17, 2023
Turns out a neighbor has a new device on channel 48 (160MHz wide) that is flooding nearby channels. I moved to channel 112 and speeds returned to normal. I don't really want to use a DFS channel but nobody else is in the higher bandwidth so I'll stick with that for now. Side note: I was also able to get better performance by selecting a channel further away (36) and lowering the throughput (channel width) to 1200Mbps, but it still wasn't as good as just moving to a much higher channel.
May 16, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Does the router feel hot or extra warm on top?
- rlmcneary2May 17, 2023Aspirant
I pulled the power from the ONT and router and left it off for 15 minutes
-restarted the ONT, connected ethernet directly to it, and measured throughput (530/530Mbps)
-restarted and connected the router to the ONT, measured the router's 1Gbp ethernet throughput (380/530Mbps)
-connected a windows machine (35Mbps/4.5Mbps), mac (20Mbps/3Mbps), and Android phone (20M/4Mbps) to the 5GHz wifi connection.
The router was upgraded to the latest firmware (see OP) then a factory reset performed prior to all of this - I did not restore any router settings.
The router does not feel excessively hot. The fan cycles at reboot, it is not running now.
- FURRYe38May 17, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.- rlmcneary2May 17, 2023Aspirant
> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Is wifi network traffic treated differently by the ONT from ethernet network traffic?
Nokia (no model number visible)
I measured throughput at the wall port the router is plugged into and it is identical to the throughput directly at the ONT. The cable connecting the wall port to the router came with the router. I measured wired throughput from the router and that only has a relatively small loss. It appears to me that the connection between the router and WAN is functioning properly.
> Any Wifi Neighbors near by? If so, how many?The 5GHz channel is 44 (-34dBm), the next nearest channel in use is 48 (-90dBm).
