rlmcneary2
May 16, 2023Aspirant
RAXE500 wifi speeds dropped
I've had a RAXE500 for about a year and in the past two weeks the wifi speeds have dropped off. I did not make any changes to the router in the months prior to the speeds dropping off. firmware: ...
- May 17, 2023
Turns out a neighbor has a new device on channel 48 (160MHz wide) that is flooding nearby channels. I moved to channel 112 and speeds returned to normal. I don't really want to use a DFS channel but nobody else is in the higher bandwidth so I'll stick with that for now. Side note: I was also able to get better performance by selecting a channel further away (36) and lowering the throughput (channel width) to 1200Mbps, but it still wasn't as good as just moving to a much higher channel.
rlmcneary2
May 17, 2023Aspirant
> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Is wifi network traffic treated differently by the ONT from ethernet network traffic?
Nokia (no model number visible)
> Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
I measured throughput at the wall port the router is plugged into and it is identical to the throughput directly at the ONT. The cable connecting the wall port to the router came with the router. I measured wired throughput from the router and that only has a relatively small loss. It appears to me that the connection between the router and WAN is functioning properly.
> What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
> Any Wifi Neighbors near by? If so, how many?
The 5GHz channel is 44 (-34dBm), the next nearest channel in use is 48 (-90dBm).
rlmcneary2
- FURRYe38May 18, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ - michaelkenwardMay 18, 2023Guru - Experienced User
So much for 5 GHz having a shorter range than 2.4 GHz.
- rlmcneary2May 18, 2023Aspirant
Had the exact same thought. Apparently they are "~75 feet away" and have two access points running. Even in the 'burbs it's getting crowded, there's about 5 "ovens" and other appliances near me.
Anyway I'm glad I could help "Brooke" get better throughput with their APs. đ
