CallIGARO
Apr 15, 2021Aspirant
Raxe500 wifi6e 6ghz network invisible to s21 ultra
Hi as the title says I am unable to see or connect to the 6ghz wifi. I've used their smart connect and also ungrouped so all 2.4 5 and 6 broadcast their ssids. I can't see any settings to tune in the ...
Apr 15, 2021Guru - Experienced User
What firmware is on the Raxe500?
How far from the router is the s21? 6e is only approved in a low power indoor mode and it drastically decreases distance it broadcasts.
- CallIGAROApr 15, 2021Aspirant1.0.1.5.2
As close as 2 feet from the router.
Thanks for the reply- plemansApr 16, 2021Guru - Experienced User
Its a tough one. Because it could be the phone or the router.
Do you have another 6e device you could test with?
Have you tried a factory reset on the router?
- CallIGAROApr 16, 2021AspirantIt's pretty much out of the box. Turned on odfma on 6ghz and changed its channel
