CallIGARO
Apr 15, 2021Aspirant
Raxe500 wifi6e 6ghz network invisible to s21 ultra
Hi as the title says I am unable to see or connect to the 6ghz wifi. I've used their smart connect and also ungrouped so all 2.4 5 and 6 broadcast their ssids. I can't see any settings to tune in the ...
CallIGARO
1.0.1.5.2
As close as 2 feet from the router.
Thanks for the reply
Apr 16, 2021Guru - Experienced User
Its a tough one. Because it could be the phone or the router.
Do you have another 6e device you could test with?
Have you tried a factory reset on the router?
- CallIGAROApr 16, 2021AspirantIt's pretty much out of the box. Turned on odfma on 6ghz and changed its channel
- plemansApr 16, 2021Guru - Experienced User
try it with the router at its defaults. (other than disable smart connect)
- CallIGAROApr 17, 2021AspirantSo I factory reset the router and the phone still could not see the 6ghz band. The router itself does have the 6ghz led on.
I've then played with settings different channels for the 6ghz band, turned off wpa3 , open etc. No change
