CallIGARO
Apr 15, 2021Aspirant
Raxe500 wifi6e 6ghz network invisible to s21 ultra
Hi as the title says I am unable to see or connect to the 6ghz wifi. I've used their smart connect and also ungrouped so all 2.4 5 and 6 broadcast their ssids. I can't see any settings to tune in the ...
Razor512
Apr 19, 2021Prodigy
Forgot to add, alsomake sure the 6GHz radio is set to use a "PSC" channel. Those are listed as preferred scanning channels where many client devices are set to scan them during their normal roaming scans, which speeds the scan time by minimicing how many channels are actually being scanned.
I have not had a chance to use that smartphone, thus I am unsure if it will manually scan the non PSC channels, or if they have it set to just look at the PSC channels.
With smart connect enabled, you should still be able to change the SSID of just the 6GHz band since it is not included in the smart connect algorithm at the moment.
CallIGARO
Apr 20, 2021Aspirant
Thanks for that tried it on both the 6ghz with a name change channel 37 psc and on the guest network. Didn't help :-/🌧️
- Christian_RApr 22, 2021NETGEAR Employee Retired
Hi CaIIlGARO,
Thanks for posting your experience with the RAXE500. I'd like to assist with the issue(s) you maybe experiencing. I have sent you a private message.
Christian
- AltsaiApr 22, 2021NETGEAR Expert
While checking 6G SSID, did you disable S21 5G LTE signaling?
- CallIGAROApr 23, 2021AspirantJust tried with mobile networks switched off and also just on 2G/3G. No change
