CallIGARO
Apr 15, 2021Aspirant
Raxe500 wifi6e 6ghz network invisible to s21 ultra
Hi as the title says I am unable to see or connect to the 6ghz wifi. I've used their smart connect and also ungrouped so all 2.4 5 and 6 broadcast their ssids. I can't see any settings to tune in the ...
Razor512
Apr 24, 2021Prodigy
I wonder, do you have any laptops or desktop PCs, with an Intel AX210, or the Killer AX1675 (rebranded AX210) WiFi adapter?
If so, then you can use winfi to check if the 6GHz band is functioning, but part of the info will be erroneous since no current WiFi scanning app has full 6E support, and the current service pack for Windows 10 has not enabled full WPA 3 on the 6GHz band yet.
- CallIGAROApr 24, 2021AspirantUnfortunately not. I'll try anything else suggested here.
Netgear Support now have my router config file for review. Will post back here on the outcome of troubleshooting in that front
