Retired_Member
Apr 15, 2023RAXE500 with firmware version 1.0.12.96 higher latency when pinging
 I upgraded my Netgear RAXE500 WiFi Router to firmware version 1.0.12.96 from firmware version 1.0.11.94. After the upgrade, I pinged the IP address of the RAXE500 and noticed that the latency of the ...
Apr 15, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices are you using to ping the router? Wired is preferred.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Retired_Member
Apr 17, 2023The Netgear RAXE500 WiFi router is connected to a Motorola MB8611 cable modem on the WAN port. I'm using good quality CAT6 cable to connect to the router.
I set the WIFi router back to factory settings. I then pulled the power plug and let it sit for several minutes. I then plugged the power back in and let it boot up. I then connected to the setup wizzard and set all settings as they were before. The WiFi router's IP address is set to 192.168.1.1. I then pinged the WiFi router at IP adress 192.168.1.1 and still got variable latency between 5ms and 11ms. I then pinged www.google.com and saw almost double the latency of normal (average of about 20ms).
I then reverted firmware back to version 1.0.11.94, reset it to factory, ran through the setup wizzard. I pinged 192.168.1.1 and the result was consistently back to <1ms. I then pinged www.google.com . It was back to normal with a latency of 10ms. What is going on with firmware version 1.0.12.96?
