sbatchik
Dec 07, 2021Tutor
RAXE500 wont allow Nest camera to connect
Have a brand new RAXE500 router and set up everything but 1 of the 4 NEST Cameras will not connect. I get error code C224. It will connect to my hotspot but not the network or guest network. I have w...
- Dec 13, 2021
Actually ot in touch with Netgear again . This time after an hour of testing, they flashed the new beta firmware and everything works great!
Dec 07, 2021Guru - Experienced User
Is Smart Connect enabled? If it is, try disabling it...
Is the camera being connected near or in same room as the router?
Also what security mode on the wifi radio are you using? Mixed WPA2 and WPA3? Try WPA2 AES only.
- sbatchikDec 07, 2021Tutor
Using WPA2. It connects right away using the old Linksys routing but the speeds were slow compared to the Netgear. I dont want to go back but need to figure out how to get this camera connected.
Thanks!
- FURRYe38Dec 08, 2021Guru - Experienced User
Try this, disable wifi security on the router. Set for NONE. See if the camera connects if so, I presume there maybe a wifi security mode issue between the router and camera.
Re-enable WPA2 and AES after checking this.
- sbatchikDec 08, 2021Tutor
Thanks for the suggestion, unfortunately it did not work. I get the same error code C224. I worked with Google for over an hour this morning and was escalted to tier 2 support who just said "Its not the camera its your router." and sent me instructions for wifi settings on router. That was a ton of help.
