sbatchik
Dec 07, 2021Tutor
RAXE500 wont allow Nest camera to connect
Have a brand new RAXE500 router and set up everything but 1 of the 4 NEST Cameras will not connect. I get error code C224. It will connect to my hotspot but not the network or guest network. I have w...
- Dec 13, 2021
Actually ot in touch with Netgear again . This time after an hour of testing, they flashed the new beta firmware and everything works great!
Dec 07, 2021Guru - Experienced User
Is Smart Connect enabled? If it is, try disabling it...
Is the camera being connected near or in same room as the router?
sbatchik
Dec 08, 2021Tutor
Smart connect is disabled. I did move the camera next to the router but still same error code. Google and netgear have been no help other than unplug and restart.
