sbatchik
Dec 07, 2021Tutor
RAXE500 wont allow Nest camera to connect
Have a brand new RAXE500 router and set up everything but 1 of the 4 NEST Cameras will not connect. I get error code C224. It will connect to my hotspot but not the network or guest network. I have w...
- Dec 13, 2021
Actually ot in touch with Netgear again . This time after an hour of testing, they flashed the new beta firmware and everything works great!
Dec 07, 2021Guru - Experienced User
Also what security mode on the wifi radio are you using? Mixed WPA2 and WPA3? Try WPA2 AES only.
sbatchik
Dec 07, 2021Tutor
Using WPA2. It connects right away using the old Linksys routing but the speeds were slow compared to the Netgear. I dont want to go back but need to figure out how to get this camera connected.
Thanks!
