sbatchik
Dec 07, 2021Tutor
RAXE500 wont allow Nest camera to connect
Have a brand new RAXE500 router and set up everything but 1 of the 4 NEST Cameras will not connect. I get error code C224. It will connect to my hotspot but not the network or guest network. I have w...
- Dec 13, 2021
Actually ot in touch with Netgear again . This time after an hour of testing, they flashed the new beta firmware and everything works great!
tonydi
Dec 12, 2021Luminary
What's the actual firmware version number on the RAXE500?
sbatchik
Dec 13, 2021Tutor
- FURRYe38Dec 13, 2021Guru - Experienced User
Good to hear. Glad NG helped out.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - tonydiDec 13, 2021Luminary
sbatchik wrote:Actually ot in touch with Netgear again . This time after an hour of testing, they flashed the new beta firmware and everything works great!
Perfect! I asked because I had massive issues with my Nest cameras and working with some great people at Netgear (Nest absolutely refused to even talk to Netgear engineers) we got some special tweaks to fix the problem. If you weren't on one of those FW releases I was going to suggest someone to contact.
