Yousef
May 16, 2023Guide
RAXE500 Your Device is disabled, Please try again in 5 minutes.
Hi, i have this issue but after reboot the router i can access normally, after 15 min its showing this message, the RAX200 not showing any issue at all, the problem from the new router itself. ...
- May 18, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Yousef
May 17, 2023Guide
May 17, 2023Guru - Experienced User
Can you try one with out the special character? Special character is an optional value.
- YousefMay 17, 2023Guide
the issue is its not accepting any password look like the real issue is login password even the reset wont works, any better idea its really big issue lol.
- FURRYe38May 17, 2023Guru - Experienced User
So can you get into the routers web page at all? Even if you disconnect the router from the ISP modem and do a factory reset and try to access 192.168.1.1?
yes its after trying and factory reset and even try to reset throw Q&A after enter the answer showing this :
Sorry,your timestamp is expired.
Please click the menu to re-enter the page.the FW just stuck on same loop with the login password, this required urgent fixed, from the app its working normally btw!
What browser are you using?
Can you try one more FR and use say Firefox or Opera browser to walk thru the setup wizard to get to the home page?If you can get to this home page, I would manually reload the FW on to the router using same browser and see if doing this will help.
Also do you have a different PC that you can compare with? Wondering if a different PC see's the same issue.Also you might try one last resort, do a 30-30-30 reset on the router and see if this helps clear this behavior.
i have to RF for 5th time and doing your instruction, the problem is i am avoid to do FR due the smart home system in my house i have RTI i need to add the ports etc any how is seems the bugs here only password with Special characters, required an updated for that, now all fine i will keep check all day and update if there is an issue with the login password or showing the same message, thanks a lot !
- FURRYe38May 18, 2023Guru - Experienced User
Enjoy. 📡
