Yousef
May 16, 2023Guide
RAXE500 Your Device is disabled, Please try again in 5 minutes.
Hi, i have this issue but after reboot the router i can access normally, after 15 min its showing this message, the RAX200 not showing any issue at all, the problem from the new router itself. ...
- May 18, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Yousef
May 17, 2023Guide
i have to RF for 5th time and doing your instruction, the problem is i am avoid to do FR due the smart home system in my house i have RTI i need to add the ports etc any how is seems the bugs here only password with Special characters, required an updated for that, now all fine i will keep check all day and update if there is an issue with the login password or showing the same message, thanks a lot !
May 18, 2023Guru - Experienced User
Enjoy. 📡
