oldmom
Aug 18, 2021Aspirant
RBR50 will not load pictured and videos from facebook or instagram
On wifi, non of our devices will load most pictures or videos on Facebook or Instagram. If we turn wifi off, they come right through. Firmware is updated, tried a reboot. No luck....
Aug 18, 2021Guru - Experienced User
1. what modem/gateway is the orbi connected to?
2. what firmware are you actually on?
3. have you tried using a different dns provider like googles at 8.8.8.8 or 8.8.4.4 or even cloudfare at 1.1.1.1
- oldmomAug 19, 2021Aspirant
1. Nighthawk CM1200 cable modem
2. Orbi Firmware V2.7.3.22
3. The orbi mobile apps shows it is using the DNS server from our ISP (Spectrum). For my desktop using Chrome, I tried a few others and nothing changed.
Thank your for your response and being polite to a non-techie.
I think the issue has to do with the cable modem, and perhaps something with IPv6? IPV6 is not being utlilized eventhough the modem supports IPv6 and "Your DNS server (possibly run by your ISP) appears to have IPv6 Internet access".
Test with IPv4 DNS record ok (0.226s) using ipv4Test with IPv6 DNS record bad (0.088s)Test with Dual Stack DNS record ok (0.242s) using ipv4Test for Dual Stack DNS and large packet ok (0.211s) using ipv4Test IPv4 without DNS ok (0.147s) using ipv4Test IPv6 without DNS bad (0.006s)Test IPv6 large packet bad (0.096s)Test if your ISP's DNS server uses IPv6 ok (0.263s) using ipv4Find IPv4 Service Provider ok (0.487s) using ipv4 ASN 20001Find IPv6 Service Provider bad (0.097s)It is all a foreign language to me.
There are posts all over the internet about this issue but none of the threads I have found give the solution. Thank you again for your time and patience.
- plemansAug 19, 2021Guru - Experienced Userdoes it work if directly connected to the modem?
