tcpwpb
Apr 29, 2021Aspirant
RBR850 unable to activate Netgear Armor
I have an Orbi for which I want to activate the Netgear Armor security. I'm unable to do this as the "free trial" feature can't be cleared and it gives an error. I don't want to pay for the subscri...
tcpwpb
May 04, 2021Aspirant
Subscribing was never the issue. The issue was with the Orbi and the ability to have the Armor security feature enabled after I had subscribed. The download and install was failing. I was able to get the feature enabled by repeatedly performing a device reset. I had to reset the device 3-4 times with the full setup steps in order for three Armor download to the Orbi. Quite frustrating and a waste of time. But at last it finally worked.
