Wayne1938
Jan 12, 2023Guide
All 5,GHz bands stopped broadcasting and are greyed out on my Nighthawk AX6600
Had no power problems and the unit is on a UPS, all of a sudden all three 5 GHz just disappeared. The 2.4 is the only band working. Go into the program and all 5GHz bands are greyed out. Any sugges...
michaelkenward
Jan 13, 2023Guru - Experienced User
Wayne1938 wrote:
When I get into the program and check wireless settings the only thing I could get into was the 2.4 settings. Both 5Ghz settings are greyed out.
Is Smart Connect enabled?
We still don't know what Netgear router you are using. (The model isn't AX6600.) That makes it hard to be sure, but after a reset this will be enabled by default. When that happens you will not be able to control the Wi-Fi SSIDs separately. They are combined.
That could be why your 5 GHz is greyed out.
This is what the manual for the RAX70 says:
Note: If you enable Smart Connect and the SSID and passwords for the 2.4 GHz and
5 GHz bands do not match, the WiFi settings for 2.4 GHz band overwrites the WiFi
settings for 5 GHz band.
With Smart Connect you will not see separate WiFi bands.
The 2.4, is working fine so can only assume the 5.0 radios have died.
How do you now that the 5GHz WiFi is dead?
To me it seems that your router is working perfectly. What you see is what I expect.
Wayne1938
Jan 13, 2023Guide
I ended up calling Netgear support before buying another router.
Found the 7-second paperclip push doesn't always work, the tech had me push it for a full minute. then turn it back on, that appears to have worked.
He took me through things I didn't know about, one being even though the Smart Connect wasn't checked he had me check it, rebooted the router then removed that check mark, as soon as I did the 5GHz bands appeared again and I could program the wireless. He had only seen that once before when someone was installing a Netgear wireless extender.
Well worth the Gearhead price. I learned a lot and now have support for a year.
The router is an AX8-AX6600-RAX 70-100NAS. That is all there is on the box other than the serial number and MAC address.
