Moose-Squirrel
Sep 10, 2022Tutor
Applied setting do not take or work
Since hooking a different 12V supply of adequate amperage it has at least not gone done losing connectivity to everything, but that has only been 3 or 4 days. When set up with that supply after a re...
Moose-Squirrel
Sep 10, 2022Tutor
Quick addendum: right after righting above I loaded the web interface and the Guest Network page Security options for 5G had a dot in WPA2-P but it was grayed out and I was unable to do anything to it. Refreshed page, came back green in none.
What is happening? Win11 with all updates, underground power with UPS reporting one 6 sec event in past 24 weeks (power pole hit), Hargray fiber.
- Moose-SquirrelSep 10, 2022Tutor
A tiny piece of the problem seems to have bared its head on about the ninth attempt to set WPA2-P on 5G guest. Instead of accepting the apply button and proceeding it popped a window prompting that a password contained"---------". After entering the password it worked. In earlier Threads I commented how there were anomalies in the web interface where items would flash momentarily and links did not work properly such as Basic/Attached Devices upper right Access Control takes you to it which is on Advanced but you remain on Basic.
Still now that I know iPhone does not like WPA2 +WPA3 on 5G guest I was able to verify that I have the same problem on 5G guest as the guest network controlling things on my main network.
SECURITY HELP
- Moose-SquirrelSep 11, 2022Tutor
Still no replies or help.
This morning I reinstalled the latest firmware, after figuring out how to change the password without being connected to the internet, for what that might be worth. And changed the passwords for guest wifi. And still when I point my iPhone to a guest wifi I access Amazon Alexa and control my lights. Even turned the allow access feature on and tested. Then turned back off and tested again. This had no effect, although I was secretly hoping something was stuck and the effort would fix.
I took a look at my machine's network to see if that might yield a clue. Since my other two machines are currently not on they did not show but look at attachment. I immediately added that to the routers block list. (I do not own a Honda)
I am now trying various settings trying to check off any possibilities of how the Echo which does not know my guest Wi-Fi is able to get info from the iPhone connected to guest. It is not sneaking through cellular because I turned it off. Wifi on the computer is turned off. Tried turning WMM off on router, no effect.
I'm secretly (oops) hoping this router melts within warranty and they send me a better one. LOL If I figure this out I already have subject for next project which I hope has some advice, good advice. (Quandary and Duplicity)
- michaelkenwardSep 12, 2022Guru - Experienced User
Try a simple explanation of the problem you want to fix.
Cut out the extraneous stuff that has nothing to do with that.
I'm finding it impossible to follow this stuff.
