Moose-Squirrel
Sep 10, 2022Tutor
Applied setting do not take or work
Since hooking a different 12V supply of adequate amperage it has at least not gone done losing connectivity to everything, but that has only been 3 or 4 days. When set up with that supply after a re...
michaelkenward
Sep 12, 2022Guru - Experienced User
The manual says:
"By default, these networks are configured as open networks without security but are
disabled."
Moose-Squirrel
Sep 12, 2022Tutor
Sorry, please explain. Not up on terminology.
Seems to me that if 2.4 has its own password and 2.4 guest has a different one the device connected to 2.4 should not be accessible via the guest if the box allowing is not checked?
- Moose-SquirrelSep 12, 2022Tutor
Oh my. The light just turned on. I had forgotten or left out of the mental loop that the command goes through their server before actuating and the server don't care if the command over the internet started on guest network.
I think my mind just explosively expanded the realm of security and near suggests I give up any effort to create security. TIA
