HiPresto
Jun 04, 2024Aspirant
AX4300 Outbound Firewall
Is there any way to set outbound rules either per MAC or per local LAN IP? I want to prevent my HP printer from constantly phoning home. I do not want to set a global rule for all attached devices, n...
- Jun 04, 2024
Thank you very much! On my tablet, I did not see the IP entry at the bottom of the configuration page, and thought it was a default global filter.
-HiPresto.
microchip8
Jun 04, 2024Master
just block its Internel access
Go to Advanced -> Security -> Block Services. Use printer's IP address and ports 1 - 65535, Protocol TCP/UDP
